R
rjcasey
Hi all, new to this forum as a member but follow lots of the threads.
In 2017 we moved in as the first owners of a new build by a small independent developer.
I am a bit disappointed by the wiring into the garage by what feels a lazy approach by the sparky or architects. The garage is attached to the property, and fed power via a spur from the 1st floor (the garage has a pitched roof so is quite high).
The spur then feeds a single socket for the electric garage door, a twin socket for use on the ground and an FCU feeding two fluorescent lights all from the single twin and earth spur!
From what I have always understood a spur should only ever be one socket off each one on the ring. I know you can have multiple spurs but each one must come from a different socket on the ring.
Surely this is bad practice. I have setup wiring for additional sockets but I will not be connecting anything until I have got someone round to wire a CU into the garage for its own ring but annoyling the house CU and meter cupboard are the opposite side of the property which means a long run of exterior cable clipped to the wall.
Would this spur have passed regs? Should I raise this with the arhetict we are in communication with over other snags.
Especially as the garage socket takes alot of high amp power tools etc.
Many Thanks in advance.
