tails are fine and correct... the only difference made to the service side was we put the cpc in to make system tncs thats all
enlighten me then.... we done a rewire of the sockets only all tested fine but when we installed the rcds they kept tripping also sometimes the trip switch wouldnt work but when you remove one of the neutrals on the the bar the test button works.
using a british genrel consumer unit with 4 neutrals going off to the 2 bars...
as soon as you put one of the neutrals on the bar...bang, trips again ??
Pay your local sparks to sort it , its not a DIY thing you've done.
Exactly what testing have you done so far?
Wiring things up and removing bits and pieces when it all goes 'bang' isn't testing. I'll ask one more time so please answer before I close the thread.
What testing have you done so far?
Tell us the tests you did one by one and the results you got for each test.
DIY PME. it gets worse!!!!! first you've either got a neutral in the wrong hole, or a shared neutral, and the |DNO gestapo will be round for mucking about with their gear.
Okay that's all I needed to hear.
Get a competent electrician in before you kill somebody.
Thread closed
Oh, and account deleted as well.
