Discuss 2x supplies down swa in the UK Electrical Forum area at ElectriciansForums.net
Interesting one. That figure would you use for grouping factors?
I suppose you could use the 3 phase figure from the tables.
Hi why would you need to group, its already rated assuming all conductors loaded?
You have two single phase supplies going to different submains, in a 4 core cable.
Do you not think grouping should apply?
Think he means 2 x single phase supplies in the one SWA.
Yes I know, just if it's possible take all 3 from the source or you could end up with 2 loaded up phases.
2 of 3 phase boards populated as single phase supplies.
Like I said no specific info but thought I'd ask.
Reply to 2x supplies down swa in the UK Electrical Forum area at ElectriciansForums.net
Hi, while carrying out an EICR at a farm cottage on Friday i came up against a problem early on. Whilst measuring the Ze the reading i obtained...
For context i am in my 2nd year in college and my head is going round in circles a question in my project for which i need to select the right...
4K
Hi guys I have some industrial lighting circuits to wire in a workshop and was after some fresh ideas/suggestions as to how i could best do this...
Been looking at a CU change in a small office and would appreciate comments on the following. Office is supplied from the mains intake in the...
6K
