is it my old eyes or is there an absence of main bonding conductors?
I can't look at it anymore, I am seeing new problems every time I look, you guys have fun, if you look really closely, especially at the right hand DB concerning cable entries you may well feel the whole thing wants ripping off the wall and doing again, enjoy yourselves lol
where does it say in the regs, cables cannot enter the side of the consumer unit, it's the top that is not allowed. All is in a cupboard anyhow.
There is no gas in the property and I'm going back to run the 10mm to the water tomorrow. The armoured cabled clamped in the bottom right wasn't done by me.
P.S my elecsa acessor has never pulled me up on the cores showing on the tails.
- - - Updated - - -
If your so good post your work smart ---????
Bodger and Badger ....
the cables are wedged under the board between the board and the wall, the board is fixed to the wall and the cables enter via the back yet appear from below and the right hand side, I cannot see any packing holding the board off the wall there, is there any?
i use 20mm brass bushes to space boards off the wall.
and the bottom right board is isolated and will be earthed in 16mm tomorrow
- - - Updated - - -
anyways I'm going out. i'll leave you boring old tods to sit there with your cup of coco's talking about how crap my work is
where does it say in the regs, cables cannot enter the side of the consumer unit, it's the top that is not allowed.Where does it say that? All is in a cupboard anyhow.
There is no gas in the property and I'm going back to run the 10mm to the water tomorrow. The armoured cabled clamped in the bottom right wasn't done by me.You've put a new board on it though
P.S my elecsa acessor has never pulled me up on the cores showing on the tails.well he should....
- - - Updated - - -
If your so good post your work smart ---????Not that stupid mate.
- - - Updated - - -
Ive posted many of my work in the show us your installs thread... so may i comment... You don't have 1 point of isolation nor are the tails secured correctly, any movement of the tails external to the boards are going to act directly on the Henley Terminations and the DB terminations... i assume you have sufficiently derated your ccc of the existing cables for the Trunking and grouping factor too.. i hope!
Most terminals are also designed on modern boards to be finger safe so leaving exposed copper is kind of defeating the object and is bad practice all the same or poor workmanship - if your assessor hasn't pulled you before its give the impression you do this often so a helpful hint - Don't!! ... and your assessor probably ran out of paper and wanted to get home for tea.
