Discuss 3 phase or not 3 phase in the UK Electrical Forum area at ElectriciansForums.net
S
shocked
Hi all
came upon a 3 phase + N supply into a domestic property with only one of the phases being used to feed the c/u.
On the cert do i put down 3 phase or single phase
thanks
john
Never assume anything, if no meters are installed for other phases then it is a single phase supply. Although I would put it down as a 4 wire 3 phase system, as long as that is what the main incoming cable is.n
That's the way I would look at it too.
Only 1 x single phase meter fitted so I'll call it 4 wire 3 phase T-N-S supply but treat it on the cert as a single phase supply.
thanks Dillb and ruston
Reply to 3 phase or not 3 phase in the UK Electrical Forum area at ElectriciansForums.net
I have been asked if I can wire a motor for a car lifter in a domestic garage, however the motor is 3 phase and only single phase is available in...
Hi I have UPS 50KVA and the inverter output AC voltage is feeding a distribution panel 120/208 V 4 wires when I check UPS display it shows me...
hi guys / girls , any advice would be appreciated, So the situation is a domestic property has a 3 phase supply , from the service head we have 3...
Wallbox Fuse Box Lite Single Phase has anyone used one of these? I've installed one feeding a Pulsar Max, the Pulsar Max is set to 32Amp max. The...
Good morning, So I’m working on an existing 3 phase solar system and the customer wants a way to use the huge mass of exported solar on their...
