L
Larsson7
Is it possible to take a feed from a 3 phase street lighting control pillar if you have a spare way on the distribution board to supply another control pillar which would then it turn supply a Vehicle Monitoring System?
Depending on the set up if the DB is permanently live and isnt switched then go for it. It's just a DB at the end of the day.
Wouldn't it be more prudent to enquire with the appropriate agency or agencies that operate or are responsible for this street feeder pillar??
it will be fine.
most traffic master systems barely use 6 amps.
ive connected supplies to a few in the past , its nothing more complicated than a Tofco cut-out in a mini pillar.
