Discuss 3 phase welder 2 phase supply? in the UK Electrical Forum area at ElectriciansForums.net
madseb
hi all
I have been asked by a friend with a small workshop to swap the plug on an ali welder he has just purchased.
upon inspection the welder has an old style bakrlight plug. and also is stated on the machine as 400v single phase 50-60hz
when the old plug as removed there was only three 6mm (l.n.e) cables preset.
after a little research, and conflicting info on here, am correct in thinking this is a dual phase supply, and that I can infact terminate the new modern commando plug, as (l1,l2,e) and allowing said friend to use it on his current 3phase outlets?
forgive the questions, but three phase is a little new to me (domestic background)
thanks in advance,
madseb
Fit a standard 3phase 4pin plug and connect as 2ph and earth .... going on the info supplied by you is correct, ensure the welder dosn't have different connection terminals inside for different supply voltages ...usually this would be evident on the Electrical plate too as it would show different input voltages.
can you put up a picture of the tally plate of the welder what type of plug was on the machine originally some. is it an arc welder some of these have diferent windings in side for different input voltages
hi, thanks for the quick replies guys.
I would be lead to belive it is 400v only as stated on he plate, I have advised the friend to open the unit to check, as this is also my knowledge of these machines
Don't you mean 3 phase supply, 2 phase welder?? lol!!
Anyway, as stated check the internal terminal connections, but sounds to me like you can just change the plug top to an appropriately sized modern commando style 3 phase plug using L1 & L2 + E ....
Good call ... even i missed that little gaff lol
i am yet to return to said premises, but ill be visiting next week, so will update the thread with a conclusion, to assist anyone searching the same queries in the future.
Reply to 3 phase welder 2 phase supply? in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone, I have been asked to pull in some new 3 phase supplies for 7 new welders which do not require a neutral connection. The client has...
I have an old Migatronic Automig X 200 welder configured as 380V 3-phase unit. Migatronic for spec. I have a 220V 3-phase point in my garage...
Been called to help a friend who can't get anyone to look at his car lift until next week and it's stopping him from working. I said I'd have a...
