A
andrewni
Any opinions on replacing a 100a main switch with 30 ma TVs, I'll have to move the internal tails from the bottom off the rcd to the top I know but is there anything to say I can't? Or just use rcbos
Sockets are covered by 30, other side is main switch, I can't see anything wrong with doing it , but was just putting it out there as never needed to do it before
So you have a split load board, RCD one side and main switch the other right? You want to replace the main switch with another RCD?
Then you'd have two RCRd in series. Bad idea
