Search the forum,
Discuss 4mm cable into the bottom of main switch. in the UK Electrical Forum area at ElectriciansForums.net
My pet hate.....Colour Harmonisation!
3 phase meter change...all grey apart from L3 load which was brown....it was grey when it was finished!
Strange thing is on CT metering all the CT wires and the sense voltage wires are red!
Couldn't agree more. Done a TPN board change a couple of weeks ago, half the blacks neutral, half phase......same with the blues. Despite the passage of time I still struggle to see how a panel of (allegedly) intelligent techies spent weeks debating it and came to the conclusion that was a good idea.
The circuit originates from the OCPD (main switch), not the 20a rcbo.
It's a little frustrating because it's one of those grey areas like multiple spurs from 1 single point and not confirming r1+r2 on minor works etc. There is no real documentation clearly outlining it's not right but we all know it's a Badgers arse
No I'm saying the circuit originates from the main switch which IMO is inadequate protection. When designing circuits you choose a protective device to protect the entire circuit.
Not necessarily. The regulations permit omission of devices for both fault current and overload current under certain conditions, such as short tails to a DB at the intake. An OCPD on the load side of those tails effectively limits the current on the supply side. The same principle allows an unfused spur from a 32a RFC when effectively the CCC of the 2.5mm is around 26a. The fact that only one twin socket is permitted means only 2x13a=26a can be drawn.
Reply to 4mm cable into the bottom of main switch. in the UK Electrical Forum area at ElectriciansForums.net
Hello All. I'm quite new to this game and gaining experience, but going well in the main. My customer wants to feed a Hob ( on island in centre...
Looking for a little advise as I’m not sure what’s happening So I’m looking at moving a two way light switch probably about 100cm away from its...
5 single phases to one huge property. Backup generator which can take about 106 amps split between 2 phases - 1 phase will be wired through...
Good morning all, long time reader first time post so looking for some help I’m qualified as an electrician but haven’t worked as a sparky for...
Hello all I have recently installed a sub main in 4mm 3-core SWA, approx length 45 metres, to feed a small garden office. Final circuits in the...
