This isn't really DIY as such, but I need advice regarding a replacement power adaptor for an electronic device.
The device requires an adaptor rated 24V and 3.3A
It has a bit of an unusual connector so it's not so easy to find but I have seen two possibilities on eBay. There's a quite expensive one rated 24V and 5A. And there's a cheap one rated 24V and 3A.
I understand the expensive one will probably be okay because it outputs more than the required 3.3A.
Will the cheap one be okay? There's not much difference between 3A and 3.3A. How exact are these types of ac adaptors anyway?
Just wondering. I'll go for the expensive one if it's likely to cause problems.
I wouldn't go for the underrated one. The way some cheaper power supplies are specced it would probably be barely capable of a sustained 3A anyway. Play it safe
Fair enough.
For the record, when I said it was cheap I didn't mean it was necessarily bad quality. They're being sold on eBay and are previously used. The "cheap" one has just been priced lower by a less greedy seller.
UK
United Kingdom
AC Adaptor amperage question
DIY Electrical Advice
Thread Tags
boney2,
boney2,
