My garage currently has 3-way switches on the inside walls at each entrance. Stepping out of the kitchen into the garage (door hinged on left) you have to take a 6" step down then reach about 14" to your left to find the light switch. Needless to say not the safest situation especially when the garage is dark.
What I'm wanting to do is mount a third switch on the wall inside the kitchen so we can actually turn the light on/off before entering the garage. Found a pathway to run a new 12/3 wire up and over the door so that's been resolved.
Pulled the two 3-way switches out of the box to inspect the wiring. What I found was that both of them only had a 12/3 wire attached to them, nothing else. That means the power is introduced into the equation somewhere up in one of the ceiling boxes. Having trouble finding a Youtube that shows someone adding a third switch where the power is not directly attached to one of the 3-ways? So, how do I add that 3rd switch with a configuration like what I have?
My plan B is to just remove the 3-way switch in the garage that's closest to the kitchen, relocate it to the kitchen wall and then run a 12/13 between it and the 12/3 wire that was attached to the 3-way I removed. Unfortunately that leaves me without a switch inside the garage on that end.
Hopefully there's a way to get this project completed?
Please describe any solution in the simplest of terms possible. Not getting any younger.
Thanks in advance, Wolf
Have you thought of using wireless switches? Then you can have them where you want and no need to run extra wires.
Just to clarify - if you haven't already sorted this out Wolf .... 🤔
A single pole double throw light switch is known as a 2-way switch in the UK, but 3-way in the USA.
The third switch added to such a circuit is known as 'intermediate' in the UK, but 4-way or 'crossover' in the USA.
I'm in the UK, so hoping my wording is not too confusing!
You need a 4-way (crossover) switch for the new position, as per post #3 above.
It has 4 terminals to accommodate two incoming travellers, and two outgoing.
And you will need 4-core Romex cable (or equivalent) in the wall to connect it up to the nearest existing switch.
The principle would be to extend the two travellers currently in the nearest switch using two cores of the new cable to the new 4-way switch, and then return the output of the 4-way switch using the other two cores and connect them into the old 3-way switch where the travellers used to be.
So you copy the functionality of the standard diagram showing the 4-way switch at the centre, but in your case it's going to be at the 'end'.
Remove the traveller wires that are currently in L1 and L2 of the old switch, and connect each of them to a separate core of your new cable with a terminal block or wire nuts/ whatever your rules allow! Then put the remaining two cores of the new cable in L1 and L2 of that 3-way switch. Connect the other end of the new cable to the new 4-way switch to match the schematic below.
Thanks for the translation, and excellent diagram 😊
Done with this stupid project! Though it is one that's going to greatly increase our safety as we can now turn on the garage lights before having to walk into a dark garage and feel around for the light switch. I was so focused on how to introduce power at the 4-way switch (which used to be the east 3-way garage switch) that I completely blanked on the simplest solution of all.
Got the two holes drilled at the top of the stud walls for the new wire routing. Got lucky there as both locations were inside a cramped side attic off the upper hallway. New 3-way rocker switch (aesthetics) in the kitchen wall. Routed a 12/3 cable between it and the 4-gang box in the garage that used to house the east leg (and power) of the route.
The simplest solution I had been overlooking was connecting the old 3-ways power onto the black wire leading to the kitchens 3-way. That introduced the power at the new 3-way switch. After that it was just connecting the Red/white traveler wires from the new and old 3-ways onto the 4-way. Just cannot believe I overlooked such a simple solution. Don't get old...
I do appreciate all you guys taking the time to send me your suggestions. I may have overlooked this solution in one of these posts but probably just another comprehension issue as experienced electricians use terms us DIYers don't fully comprehend at times.
Thanks again,
Wolf
