Advice after drilling through electrical cable above plug socket
You may well take the Micky about using ferrets but many years ago when the CEGB [ the forefather of National Grid ] were laying very high voltage cables under the Seven Estuary they had to install a draw wire into the steel pipes under the bed of the estuary and they got the initial light string through the pipe by tying it to a ferret and placing a rabbit at the other end of the pipe.
OP: Of course, this all depends on the size of cable.
We can use anything from small hamsters to young children for pulling cables...
Took twenty of us to pull a new cable into place at work, mind you it was three inches thick.
Depends on the type of hamsters, mate...
One (standard) hamster is approximately 0.000237Ap (where Ap is of course the usual unit and abbreviation for 'apprentice').
So, by simple arithmetic, we can deduce that we need 4,213 hamsters to replace the pulling power of one apprentice.
Although it is inconvenient to provide facilities to feed and water so many hamsters unless one has a very regular requirement for them it is always worth bearing in mind that they can be sent down very much smaller holes than any apprentice could hope to negotiate.
If you are in a hurry it is possible to temporarily increase the work output of your hamster team by waving a cat around at the rear of the group. This does work quite well and it is possible to achieve short-term increases of up to 300% at the expense of some hamster casualties as a result of heart attacks.
Hi all,
I have stupidly drilled through the same electrical cable TWICE 1 inch apart. This is above a twin plug socket which obviously now doesn’t work. The holes are about 1m above the socket.
As a temporary measure I was going to connect the wires individually with Wago connectors but the 2 whole problem has thrown me!
Will it be okay to replace the broken part of the cable and use wagos at each end?
Or is it better to replace cable from the break to the plug socket (so just one set of connectors being used?) Is it a case of attaching a new cable to the end of the old one and greasing / pulling through the socket?
Hope all that makes sense. Advice much appreciated!
Read up on safe zones before continuing. You shouldn't drill anywhere vertically or horizontally near any electrical outlet.
And finally before making circuits live, hire a qualified electrian to do testing. Mind you, it may be difficult as most electrians won't touch such work. Electrians are liable to leave circuits safe, if you bodged up the work it may take take several hours/days to rectify.
Even though I done electrical course, I didn't feel I was competant enough to do such work. Now I restarted working with a qualified electrian to learn trade properly. Not worth risking life over few thousand. Wish you all the best anyway.
Few thousand... if you're getting into this game for the money, you're going to be sadly disappointed. Couple of hours £80 is what I'd quote (without seeing it) :)
