T
timo1
Hi,
Has anyone on here had any experience on fitting an a decent modern central heating system? I have a customer who is looking to purchase a flat which has no gas supply so the only option available is an electrical system.
I dont have any experience with a modern system of this type and was wondering if anybody has installed anything that is modern and cost effective to run. At the moment its likley to be a fairly decent rewire as all wiring is surface and if the sale goes ahead will be changed.
TBH I thought that you would be limited to storage heating as your main option.
Any advice would be welcome, all the best.
Tim
I have no experience of them but electric boilers that heat radiators just as a normal gas boiler does are available.
There are many various sized electric boilers around that run radiator systems
You need to be sure that the dwelling has enough capacity to do so,it can become a problem because these properties would generally include electric showers and cookers
As for cost effective,they will effectively cost the punter a small fortune,persuade them to go for oil
Thanks for the replies. I will have a chat at my wholesalers, I cant imagine anything electric being too cost effective!
Are you going to install a full system? If so, I'd price it up and compare it with the cost installing energy efficient radiators. I fitted a couple for a client about 8 months ago, she's was more than happy with the price and the efficiency of the system. I got them from this company I think Energy Efficient Electric Radiators
- - - Updated - - -
Are you going to install a full system? If so, I'd price it up and compare it with the cost installing energy efficient radiators. I fitted a couple for a client about 8 months ago, she's was more than happy with the price and the efficiency of the system. I got them from this company I think http://www.greenvisionheating.co.uk/energy_efficient_electric_radiators.html
Looked into the electric boilers a couple of years ago for 3 new flats and couldn't get the figures to stack up against putting a gas supply in and the costs that incurs as the load these things run is just ridiculous.
On the average domestic electric supply if you are trying to run an electric boiler you have to include for controls to shut down the boiler if the electric shower is being used and given some of the loads of electric cooking takes these days you will have to do something on that as well
There are other factors to consider but not worth the time when you look at the basic costs v gas heating
Hi all, thanks Jimmymac I will look at that site. Ung, I agree. I've been told on the phone that gas cannot be installed, although there used to be a supply so i would need to check. TBH installing a full system with controls is a bit out of my comfort zone so I may just advise about the gas being reinstalled and point them in the direction of some energy efficent radiators.
While space heating is one problem the other is water heating which can become expensive on electric
If you have the time to do the paper exercise it can be worthwhile comparing various fuels as to being cost effective especially if you include installation costs and payback periods for alternatives
The last time I did this was about 20 - 25 years ago to prove that economy 7 was not a good option to some one it did actually change their mind
A current sensing relay to drop out a contactor for the boiler in the cons unit, when the shower draws current may be all that is needed
I've fitted a few Heatrae Sadia Amptecs now, great pieces of kit! Combined with a new and efficient unvented cylinder and you have the exact equivalent of a conventional system and are just as cheap to run as a gas boiler. No need for electric showers then also.
They range from 6kW to 11kW I believe.
