Discuss air source heat pump, forward planning for cables to install in the Central Heating Systems area at ElectriciansForums.net
hi
I have wired up various central heating systems, y-plan, s-plan, under flooor etc . but i will be doing an air source heat system. They have not yet purchased the pump, but i am on with first fixing and i am wanting some advice on what cables are needed before any of the plans / instructions come through. All i have been told is there is a air source heat pump and two water cylinders going up stairs. ground floor has u/floor and upstairs has radiators.
without any plans yet i am guessing - I understand a typical air source requires a 32 amp supply, but will hold fire on that until i know the true size of it.
Does the pump then just require a l/n/sl/earth up to the cylinders for controls, presumably this is fused down in the air source pump, or a seperate fused external supply to be installed up to the cylinders.
No idea what set up these pumps / systems use. Any help or advice on what is needed, or basic schematic , principal would be much appreciated.
thank you.
Reply to air source heat pump, forward planning for cables to install in the Central Heating Systems area at ElectriciansForums.net
Hello, I hope you are well, I have fitted a few Nests but only to Combi, S and Y plan systems just been looking a job where I’m doing the kitchen...
I've always thought I was quite good a wiring heating systems, I can do Y plan, S plan, UFH set ups, "normal" thermal stores etc, you name it and...
Hello , I’m trying to further my knowledge into UFH/Rad/HW valves heating systems with air source pumps. What is normally needed outside with...
Client currently has a DB in his outhouse. It feeds a pool pump and an air source heat pump. It is currently being supplied using a 4mm T&E cable...
I have a large gym in the garden and it gets ridiculously hot in the summer. I have utilised pretty much every inch of space and do not want to...
