Discuss Alarm sounds when deactivated in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Don't normally deal with alarms but a customer has asked me for advice and consequently I come here!
Old system (circ 1980s) occasionally alarm goes off during the day when its been de-activated, type in their code and it stops and everything OK until the next time. Happening more regularly.
New battery required?
Hi,
Mine sounds when landing light is turned on and then stops when it is turned off. All other room lights do not affect the alarm. Baffled why I get this affect with only one of the upstaris lights as it appears to rule out any voltage drop that might be sensed by the alarm unit. System is an old wired installation.
Grateful for any ideas please.
Hi,
arcing in the light switch or fitting could cause this. check all connections relative to the landing light and if necessary, replace the switches ( i assume it's 2 way ).
Reply to Alarm sounds when deactivated in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Daughter has bought a house and it has a home security system, G-Tag setup. Issue is the alarm panel displays are pixelated and you cant see...
Hello. Wondering if someone could give me some advice on my Veritas alarm. I recently had an extended power cut, when the power was...
My burglar alarm went off last night when it wasn't even set. When I went to Keypad it was showing TAMPER with a Red light. I could not silence it...
13K
Hello All Can I say to start with I am not an electrician but used to be a heating engineer (yes I can hear the groans). I have wired the...
14K
