T
thekingiam
Just read a blog stating all cu in domestic to be fire retardent is this true and does that mean all cu to be metal
January 2016 is the date for this. More worryingly is the requirement for all cable entry points to be fire retardant too so this is going to be expensive.
this was covered by the NICEIC at elex last week and I asked if a smoke alarm could be installed in the location of the cu instead - which I thought was a perfectly reasonable idea but Tony Cable didn't
Right, for the umpteenth time, no, new CUs and switchgear do NOT need to be metal.[b/QUOTE]
Unfortunately, this has still not been finalised.
At present, it would appear that metal CUs are going to be the requirement.
The Glow wire test of 960 degrees appears to have been dropped.
As far as I can tell, the consensus is metal on the IET forum.
Apparently there has been an increase in CU fires in the UK over the last few years.
Wouldn't surprise me to find that it's due to these so called 17th edition boards.
