Discuss American FF tripping RCD in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
As others have said the best option is to get it fixed, if it's less than six years old (five years in Scotland) they could claim against the supplier, it's unlikely that anything other than a manufacturing defect would cause intermittent RCD trips in a new-ish product.
If all else fails it could be powered from an isolating transformer, fridge-freezers don't take much peak power so a transformer wouldn't be a silly size or cost. It would be a bit of a hack but so long as the earth bond is maintained it would be safe and would prevent RCD trips.
Does it record the info or do you have to watch it and wait for the moment it trips?
It will record either min or max for as long as the supply is on.
When supply is off(trips) it stops recording data but will leave you with a reading.
I have a mock up adaptor I use to separate L N E in the appliance flex as clamping the flex as a whole will give no reading.
I was without one until a year ago it really does save alot of agro.
Thanks!!
Reply to American FF tripping RCD in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi I am asking for help as a novice and 1st time user of this forum. Recently started to experience tripping of MCB & sometimes with the RCD at...
Called out to fault on RCD tripping maybe twice in a month for sometime. Did all the tests & found RCD was faulty, Refitted a new Rcd Type A which...
I'm writing this mainly hoping something occurs to me while writing it! I got called to an occasionally tripping RCD. It's a Hager double height...
Hi Guys, I'm having trouble diagnosing a fault on a customers downstairs socket ring, which only ever trips when the washing machine is used. The...
