Discuss Android app EasyEngineer in the Electrical Engineering Chat area at ElectriciansForums.net
A
afonsoeiro
https://play.google.com/store/apps/...sMSwxLDEsImVhc3luMS5lYXN5LkVhc3lFbmdpbmVlciJd
offbQfWHatO4uMh8we2sY64Tapmkh0oiBFiCArL21SVbZRUcFt3LiDc_EEjEEmLyFQ
Only for screens with 4'' and less.
With EasyEngineer you have more than 180 calculations available, divided in 6 areas. It's a huge amount of calculations capacity and a helpful tool for the daily work.
Areas included:
- Electrical
- Chemical
- Mechanical
- Communications (only antennas)
- Conversions
- Electronic
Electric area:
- DC Motors starting current
- DC Motors current after start
- DC Motors Induced voltage
- DC Motors Net voltage in the armature
- DC Motors Mechanical power developed by the motor
- AC Motors speed
- AC Motors torque
- Footcandles & Lux
- Footcandles & Lumens
- Lux & Lumens
- Light level at a point
- Average reduced carbon dioxide
- Average reduced Sulphur Dioxide
- Average reduced Nitrogen Oxides
- Spacing between fixtures
- Light output ratio of luminaire
- Room index
- Wind power
- Kinetic energy
- Turbine power vs wind speed
- Annual energy output
- Energy consumption estimation
- Power calculations
- Power factor calculations
- Photovoltaic (PV) solar panel calculations
- Photovoltaic (PV) solar battery calculations
Communications area:
- Ground planes antennas
- Halfwave verticals antennas
- Quad antennas
- 5/8th wave vertical antennas
- Camera MPEG-4 CIF bandwith calculator
- Camera MPEG-4 4CIF bandwith calculator
- Camera H264 CIF bandwith calculator
- Camera H264 4CIF bandwith calculator
- VOIP calculations
- g.711-64.00kibps
- g.722-48.00kibps
- g.722-64.00kibps
- g.723.1-6.10kibps
- g.729a-8.00kibps
- iLBC-15.20kibps
- GSM-13.00kibps
- Ipc-2.50kibps
- g.726-32.00kibps
- RAID disk calculations
Chemical area:
- Ideal Gas law
- Boyle's/Mariotte Law
- Charle's law
- Equivalent Oxygen Weight
- Ether extract
- Estimate Fatty acid
- Oxidizing and reducing agents
- Estimation solution protein
- Estimation of calcium
Mechanical area:
- Spur gears circular pitch
- Spur gears diamentral pitch
- Spur gears pitch diameter
- Spur gears addendum
- Spur gears outside diameter
- Spur gears number of teeth
- Spur gears Dedendum
- Spur gears working depth
- Spur gears whole depth
- Spur gears clearance
- Spur gears center distance
- Spur gears base diameter
- Spur gears pressure angle
- Specific gravity with water
- Flow rate
- Fluid pressure
- Absolute pressure
- Manning flow velocity
- Minor losses
- Specific volume
- Pump eficiency
- Stokes law
- Darcy law
- Mean depth
- Parshall flow rate
- Area of cross section (pipes)
- Weight in pounds (pipes)
- Moment of inertia (pipes)
- Section modulus (pipes)
- Radius of gyration (pipes)
- Break power (pumps)
- Specific speed PD pumps
- Pump displacement
Conversions
- Centimeters
- Feet
- Inch
- Milimeters
- Candelas
- Lambert
- Nit
- Stilb
- Footcandle
- Lux
- Nox
- Lumens/square meter
- BTU
- Watt/hour
- Joule
- Gallons (US) of Kerosene
- Celsius
- Fahrenheit
- Kelvin
- Rankine
Electronic area:
- Coil inductive reactance
- Q of a coil
- Coil self-capacitance
- Inductance od a single layer coil
- AC resistance
Reply to Android app EasyEngineer in the Electrical Engineering Chat area at ElectriciansForums.net
For a Mechanical Engineer, challenges don’t come any bigger than this… In this role you’ll be responsible for the key capability of a nuclear...
Swanemi
N
Hello, new to the forum so have a quick question, I have just completed 22 years as a Electrical and Mechanical Engineer in the Britsh Army...
Neil H
N
G
Taken from www.firemagazine.com Crown Court sentence for fire alarm engineer A former retained firefighter from Wales who failed to maintain...
accordfire
A
