Discuss Angled soffit LED downlights in the Lighting Forum area at ElectriciansForums.net
gazdkw82
Need to install some soffit lighting (downlights) into the soffit of a bungalow. The problem is soffit itself isn't 90 degree horizontal with the building, it's more light 45 degrees.
Installing downlights into this would just create a small spot of light on wall.
Does anyone have any recommendations on a angled spotlight suitable for soffits?
You get asymmetrical spotlights in two varieties, one type has the lamp offset from the centre of the fitting and angled, the other type has optics built into it that makes the light angled, almost like a car headlight. Both of these types would sit flush into the soffit.
I'm not sure what's readily available in the UK but you could also use a fitting that can be angled like this for example.images.jpg
Or maybe look at a ''wall washer'' type light.
I think it has to be adjustable. Zerax is right, it could stand out if it's not right.
So I guess I'm looking for an IP56 or greater, angled spotlight suitable for soffits.
i've had IP20 downlights in soffit for 10 years. no trouble. rain comes down, not up.
It won't need to be ip56 in soffit they won't get soaked, I've seen normal ip20 spots installed many times with no issues bar some corrosion to older ones
Ansell Iris are nice lights but may prove costly if you have a lot to do. From memory they are about 40mm cut out, available in white/satin and have a good adjustable range. Also dimmable but will need wiring in series.
Reply to Angled soffit LED downlights in the Lighting Forum area at ElectriciansForums.net
I need some help locating suitable led downlights to be installed in rigid celotex, they are being installed in a flat roof but there is 70mm of...
5K
Hi all, a very long time I did a swanky grand designs type new build in the middle of nowhere, so in the middle of nowhere that it's a house with...
Hello folks, Just looking for a little guidance please. I am sure that this is something that many of you have come across before. I am...
Want to install a Ring Floodlight Pro at an angle (say, at almost right angle to wall). Is there a suitable 90 degree bracket that might suit...
Hello all. I want to fit LED strip lights to the ceiling with 45 degree channeling and diffuser around my son’s room. As there are so many...
