T
TPES
Your opinion on coding these please.. (16th ed Split load CU)
Grid plate in kitchen, Has "washing machine" & "Boiler" behind the grid plate is 2 different circuits, The washing machine is on the RFC, and is RCD protected, also behind the grid id the boiler circuit which is not RCD protected (On main switch side).. Is this worthy of a code?
In the kitchen is a FCU with the label "Cooker" on it, The feed into this is off the RFC, the load side out is in 1.0mm but can not trace where it is going too... Code 3 ????
Above the cooker up high level in the kitchen is a single blank plate, Behind is a 1.0mm t&e in a connector block, Although every circuit is on and switches in the kitchen switched on i cant seem to liven this t&e at all.. Worthy of a code..?
Also on the outside wall is a extractor fan grill, but in the kitchen opposite the grill is no fan! if you tap the wall it feels hollow, as if there was a fan but has now been boarded over.. But surely there will have been a feed there at some point for a fan... But can see any isolator in the kitchen for any type of extractor fan.. Is this worth mentioning on the report?
Last one...
There was an old garage feed that has now been dissconected out of the CU, no MCB, no label, No signs of there ever being a feed for a detached garage.
but there is an SWA on the outside of the house with the lid off the IP box with conductors showing at one end, and on the garage there is the other end of SWA terminated in an IP box with the lid on but it is not fixed correctly to the wall... Is this worth mentioning or if a cable is dissconnected at both ends and not in service do you just ignore it?
Some of these maybe simple to some of you, I dont pretend to know it all and im always learning, especially when it comes to PIR coding.. I will be getting more and more periodics to do so i want to be sure on my coding and i know this is the place to come for advice...
Last one...
