- Jun 4, 2017
- 3,806
- 5,856
- 12,688
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Practising Electrician (Qualified - Domestic or Commercial etc)
- Business Name
- Sulis Electrical Services Ltd
I have a customer who lives in an exceptionally large house on outskirts of Bath. for context the previous tenant was a billionaire!
Initially wants a 22kw 3 phase AC ev charger, no problem there subject to DNO confirming the supply is adequate and fuse ratings etc..
He is lucky as his house is remote and a few hundred meters from the nearest property and he has a WPD DNO substation/transformer on the property around 30m from the current cut out/garage.
Wants either now or when garage is rebuilt to have a 50kw DC Rapid Charger installed.
Sort of took me by surprise but is adamant he wants one, even after telling him the £12k + cost just for charger before ground works, switchgear and labour price doesnt seem to faze him.
I cant see DNO ever allowing that off the house supply so will if they even allow it at all charge a fortune for new connection just for the charger. he will dig trenches using his own groundworkers so DNO only need to run cable. will still be expensive!
I know from previous experience with the DNO that they say a 50kw DC charger uses same network capacity as 25 gas heated new build flats so they dont exactly like them!
Never been involved in fitting one in a domestic setting before, fitted 2 in a company car park but thats about it.
anybody else fitted DC Rapid chargers in a house / mansion?
