1shortcircuit
lol
Thought I would bring this topic into here in the hope that someone may be able to assist :)
Went to view a clients property this evening as he is suspiscious that his electric meter/controller for the circuit/s oil filled safety radiators is on it's last legs.
I've taken a couple of pictures as the unit looks old and I've no knowledge regarding the system being used. (I will upload as soon as possible)
The meter tails are split via henley block. A set of tails go to the CU and a set go to this monster metal enclosure. The enclosure has a main switch and two dials that make hell of a racket. Apparently, recently the dial for the BEDROOMS was going backwards and the heating not working?
The controller is split as follows
LIVING ROOMS BEDROOMS
Push Buttons CLOCK BYPASS OFF BYPASS CLOCK
Anyone know what I am chatting about? lol Please? :thumbsup
bedroom clock going backwards and heating not working sounds like it might have somehow ended up being wired with reverse polarity, so I'd test this before doing anything else.
eta - then again, I've only done a small amount of heating work so could well be talking rubbish- most of it has been replacing kit like this though.
Nobody had touched it, working fine then when it was noticed that the heating was not working they discovered the clock was going backwards but only on the one clock. It has since corrected itself and the heating working again but I have been asked to look into a unit that will replace the very old clock version. I've been searching google but don't think I am putting in the correct searches as I am not finding anything.
:thumbsup
Re: Anyone know what I am chatting about? Heating system... - Pictures Added
As promised ;)
You could probably construct something bespoke if nothing can be found 'off the shelf'.
Seems it would only be a couple of contactors & timeclocks in there.
Ah, that sounds like a job for a "Proper" electrician ;)
Is this lot just feeding individual radials out to separate oil rads?
This is what I believe.
I haven't removed the cover, just popped by to see what the setup was in the hope that there would be a more modern equivalent available lol
Each oil radiator has it's own fused connection unit (with flex outlet) so I am "Presuming" there is one radial for the two downstairs rooms and a separate for bedrooms OR A radial to each radiator from the appropriate controller?
I can feel a revisit required and cover removal with further photos lol
Well, if it's as simple as that, then if all the customer wants is them switching on/off at set times (like e7 for example) then just fit a perfectly ordinary digital or analogue time clock, to a 2p contactor rated for the circuits (40A maybe?), a 4/whatever way RCD garage board fed from it and you're home for tea.
That's exactly what the customer wants. A heating system that can be controlled like most others with a digital timer but still use the existing rads as they are working fine:thumbsup
In thinking about it some more, if you wanted to get clever and neat, you could fit a din rail time clock, 2p contactor and the necessary cpd's all into the same DIN rail unit. Tidy. And maybe even home for lunch if the wind's behind you.
I shall look into that more Rockingit, Thanks for your input... Very much appreciated. I'm sure I'll have further questions so hope to post back soon:thumbsup
1shortcircuit,
1shortcircuit,
