PART A
Im looking to fit an Aqara smartswitch to turn some external lights into Auto on lights for any one coming to the doorway - Sensor to be added. All run through to Homeassistant.
And perhaps the hall way lights (ceiling gu10 spots) also.
My existing wiring has confused me though - but I've little experience here
tested all the wires below as follows - and to note there are neutrals all capped off in socket and earths.
1 - Seems to be dead whatever!? - COM1
2 - SWITCHED LIVE: Right rocker indoor lights - L11
3 - PERM LIVE: - Right rocker indoor lights - L11
4 - PERM LIVE: - Left Rocker - Outdoor lights - COM
5 - SWITCHED LIVE: Left Rocker - Outdoor lights - L21
Question 1. Does it simply go that
  • LIVES 3 and 4 go into L
  • LIVE SWITCH wire 2 goes into L2
  • LIVE SWITCH wire 5 goes into L1
  • Dead wire i cap off?
Question 2. Any known risks of this not working ?
Question3. Can i link into HA to also use to to dim lights ? or is that not functional?
QUestion 4. If anyone knows Homeassistant im led to believe you can also use the switch to run automations - ie double click could lock smart lock behind me and say turn off all the lights?
Question 5. does it fit a 25mm box from experience? Considering spacers if not as only a hallway switch.
PART B.
The oher option i have is a sonoff relay SONOFF ZBMINIL2 Zigbee Smart Light Switch (2 Way)
Question 1 could that be used on this double switch the old rocker that is. as an option. or can it only be added to left or right rocker (would i need two?)
Question 2 could this be used in the chain of bulbs in the ceiling (ie GU10) spots in the front room that has 3 switches that turn on and off? Im led to believe thats where you use thembut at what point in the chain - ie is there a FIRST light it needs sit infront of?
