Discuss Arching from neutral on stud work in the UK Electrical Forum area at ElectriciansForums.net
Hi all,
took s load of sockets off on a job and plasterers have been in to take the plaster board off , builder rang me and he says its arching on the stud work from the neutral, going down tomorrow to have a look, lives are out of the RCBO's but earths and neutrals still connected.
you guys give me the best course of action?
cheers
Always disconnect Live and Neutral from consumer unit in these instances. I'd always put chocblocks (strip connectors) on the open ends aswell just incase some muppet reconnects the cables at some point....i will add within a domestic situation this should be the only use for the good old chocblock as there's far better other methods for jointing cables as a more perminant solution.
Reply to Arching from neutral on stud work in the UK Electrical Forum area at ElectriciansForums.net
Evening all. I did an EICR recently and then changed a consumer unit. As part of the EICR process I take off around 25% of all accessories to...
Hi all, Was speaking to a family member recently, he told me his iron recently made a bang and flash as he plugged it in to the socket, and could...
Hi! Some help would be appreciated! I've just moved into new house, wanting to check insulation resestance etc as getting some nuisance...
Did a check on a ring circuit, due to board having to remain live I did it at a socket.. Was an RCBO, had checked RCD side and all tested ok...
