Discuss Are mains sockets permitted in bathrooms? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hello. I am extending my bathroom, but one of the walls that will be incorporated into the bathroom has a socket fitted. Is this allowed in a bathroom or is it best to remove the socket and fit a cover?
13A socket outlets are permitted providing they are not less than 3m from the boundary edge of zone 1.[/QUOTE
Thank you for your quick reply. The socket is too close to zone 1. Behind the socket three cables converge, bearing in mind that I am replacing the plasterboard in that area what is the best method of connect the cables together?
'Thank you for your quick reply. The socket is too close to zone 1. Behind the socket three cables converge, bearing in mind that I am replacing the plasterboard in that area what is the best method of connect the cables together?'
Either use the existing back box, suitable connectors and a front plate or a suitable maintenance free junction box. Any further information, would be a step by step guide, which is against forum rules.
I'd consider employing a competent electrician. Such work could be notifiable to local building control.
Designate your bath as a swimming pool, and as long as its rcd protected you can reduce the distance to 2 metres. :)
I am kidding of course but it's in the regs 702.53ii a socket outlet is permitted in zone 2 and that's 2 metres from the edge of the pool
Thank you, could you recommend a suitable maintenance free junction box?
I gave you a Funny because it's one of those situations where doing it just before knocking down the wall wouldn't be notifiable, but after would.
Anyway, not a lot of people realise that replacing a bathroom is classed as building work under the building regulations and should be notified to the local building control.
The day anyone on here notifies building control they are doing work in their bathroom I'll eat my hat lol.
Well you will be the first one that has ever done it lol
Reply to Are mains sockets permitted in bathrooms? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all, Got an awkward bathroom fan installation in a downstairs flat, concrete ceilings and (some) walls. Bathroom is already fully tiled and...
I have a socket in by bathroom vanity unit, .75m away from the edge of the bath. The vanity is completely enclosed with a sink on top and doors...
Had to remove a led strip from a bathroom today because it’s getting tiled, now the led strip that was there was low voltage but didn’t have...
Hello all, I need to have an electric car charger installed but at the moment I'm puzzled about what my options are. My garage is at the back of...
