IPF, lets see if any are on special offer on Saturday. See you then![]()
pm me some details, see how I'm fixed. Cheers in advance.
he is talking about the build it toolshow on 7-8th feb at eventcity. i might get the train, google is saying its a 90mile 2 hour drive.pm me some details, see how I'm fixed. Cheers in advance.
yes you will get then undone with a spanner, wera joker spaners keep going when my impact driver cant tighten anymorejust seen this thread-I have a set of the Armeg cutters, great because I use them in my impact driver, along with a 4-12mm step cutter for metal cutting (holes.) The 32mm wore out very quickly, but other than that they are very good. I actually like the ridge round the cutter as it stops over penetration. I get mine from ITS-I have a local outlet. The 4-12mm step cutter knocks 10mm hole through struts all day long. I am aiming to have a complete tool kit I can use in my impact driver, especially for metal munching (I do a lot of it.) Already got 17mm and 13mm impact sockets that fit inside struts and it's SO much quicker than loadsa drill bits, spanners, sockets etc. and you WON'T get them undone with a spanner when they're done up this way.
defiantly true, on trunking you can see it bending when using 8mm bolts if you over tighten it.Do you ever stop and think maybe you are over tightening things?
All fastenings have an optimum tightening torque, under that and the won't have tensioned properly, over that they begin to stress and weaken the fastening
on rawl bolts i would rather use a socket set after using impact driver if they use very long bolts
we use 8mm bolts when bolting it to unistrut or 10mm rawl bolts into wall.Apart from trays I never drop below 10mm bolts for panel mounting or unistrut work.
same, i use them in brick as well.I use Rawl Bolts for non concrete walls too.
