- Reaction score
- 6,974
IPF, lets see if any are on special offer on Saturday. See you then
pm me some details, see how I'm fixed. Cheers in advance.
Discuss Armeg Sheet Steel Hole Saws in the Electrical Tools and Products area at ElectriciansForums.net
he is talking about the build it toolshow on 7-8th feb at eventcity. i might get the train, google is saying its a 90mile 2 hour drive.pm me some details, see how I'm fixed. Cheers in advance.
yes you will get then undone with a spanner, wera joker spaners keep going when my impact driver cant tighten anymorejust seen this thread-I have a set of the Armeg cutters, great because I use them in my impact driver, along with a 4-12mm step cutter for metal cutting (holes.) The 32mm wore out very quickly, but other than that they are very good. I actually like the ridge round the cutter as it stops over penetration. I get mine from ITS-I have a local outlet. The 4-12mm step cutter knocks 10mm hole through struts all day long. I am aiming to have a complete tool kit I can use in my impact driver, especially for metal munching (I do a lot of it.) Already got 17mm and 13mm impact sockets that fit inside struts and it's SO much quicker than loadsa drill bits, spanners, sockets etc. and you WON'T get them undone with a spanner when they're done up this way.
defiantly true, on trunking you can see it bending when using 8mm bolts if you over tighten it.Do you ever stop and think maybe you are over tightening things?
All fastenings have an optimum tightening torque, under that and the won't have tensioned properly, over that they begin to stress and weaken the fastening
on rawl bolts i would rather use a socket set after using impact driver if they use very long bolts
we use 8mm bolts when bolting it to unistrut or 10mm rawl bolts into wall.Apart from trays I never drop below 10mm bolts for panel mounting or unistrut work.
same, i use them in brick as well.I use Rawl Bolts for non concrete walls too.
these?On the subject of fixings (hope I'm not off topic) I use fixings in concrete that just require a pilot hole, then are put in by the Impact Wrench, though I can't remember what they're called. They are quicker than the usual wedge anchors, though more costly, and don't require the carrying of any setting tool.
Reply to Armeg Sheet Steel Hole Saws in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for. It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online. Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
We also have a Tiling Tools advice from the worlds largest Tiling community. And then the Plumbers Forums with Plumbers Tools Advice.
