shinypen
Hi.
I'm pricing up a job. I need to run bell wire up the outside of a newly rendered and externally insulated house. Never touched this before and I'm worried the clips won't fix in securely or will damage it. Is this the case? Any one got any experience /tips?
Thanks.
It's a massive victorian 3 story house split in to flats. The renderers helpfully pulled all the wire off when they did their stuff.
It's for 4 door bells. Didn't want to use trunking as thought a bit OTT but perhaps not as they'll be 4 wires. Perhaps wall plugs? Do plugs even fix securely?
The render can be fairly soft and inconvenient to fix to, perhaps using pin plugs may help, alternatively using a screwed P clip can allow the use of longer screws which will hold to some extent in the insulation but you should ensure that you are not breaching a water barrier, so seal the screw entry. The cables should not be subject to heavy strain.
Internally all the wire runs to the external wall where it was ripped out so would have been nice to utilise this. There's scaffolding up also. P clips may work.
Can you run an 8 or 12 core Alarm cable internally to a central junction ?
from the junction to each Bell in 4 core. Alarm cable is small and unobtrusive & can be easily hidden.
