I tested a non working outlet with receptacle tester and it said open neutral. Turns out that the neutral wire was loose. BUT, in order to shut off the power I had to turn off 2 circuits. Inside the box was only 2 wires, black and white.
So the open neutral is fixed but how many other problems do I have now? None would be a good answer but don't think it would be correct. Thanks in advance.
It really depends on how old your house is. Back in the day and I’m not going to call them electricians because no way should you have to cut 2 breakers off for one 2 gang box. I’ll guess and say your house was built in the 1950’s. Be careful
