Discuss Bathroom fan stays on when cfl lamp is fitted in the UK Electrical Forum area at ElectriciansForums.net
O
oldtimer
Guys got a call this morning customer changed the lamp in the bathroom from a standard incandescent to a energy saving lamp and when he switched the light off the fan kept running so I asked him to check it with the lamp removed and the fan went off after 5 minute as it should.
So I have never seen this before anybody else had this.?
Had very same problem and have had problem with flo tubes when added a new fan, changed fan for xpelair problem sloved, cheap fans anit worth the bother now everything is going energy saving in my opion
Reply to Bathroom fan stays on when cfl lamp is fitted in the UK Electrical Forum area at ElectriciansForums.net
Good afternoon everyone. I have fitted an extractor fan in my bathroom with an overrun timer, to start when the bathroom led lights are turned on...
8K
Old two core cable in a lighting circuit with no cpc at any point All points had metal fixtures and fittings class1 At two points the live loop...
I'm not sure what's going on with my kitchen light. I've replaced an old 28W CFL fitting with a new 4 x LED GU10 fitting (a cheap one from...
hello all, pardon my ignorance in not employing an electrician, however, im a diy'er whos changing the light switches in my house and came across...
Hello, I had and electrian fit a bathroom xpelair lv100ts bathroom fan. It works fine but the timer won't stay on after the light is switched...
