Got a few changes I wanted to make in the bathroom, just searching through the threads there are all sorts of regs and zones and acronyms as a DIY-er I'm not familiar with. Following are the jobs I want to do, give or take I've got all the parts but now wondering if I should be doing these myself. Would appreciate yes/no's on if its possible and if I can take this on or I should seek a qualified electrician?
1. Replacing the existing lightfittings with new ones.
2. Adding an additional single light on a seperate switch (so going to the bathroom at night I can flick on a single light with a low wattage bulb so I don't blind myself with the four main lights, this idea came from a hotel I stayed in).
3. The extractor fan is currently wired to the light circuit, I want to move this to a seperate circuit/switch. I have got a fan isolator switch to go on the landing which it currently doesn't have to isolate the constant feed as it does have a run on timer.
4. The lights are currently switched from a pull switch in the bathroom, I want to take this out and add switches on the landing (for the 3 above mentioned circuits).
5. Adding a shaver/toothbrush charger socket in a cupboard in the bathroom (and would this go to the upstairs socket ring main or be wired to the lighting circuit, can't see any indication on the unit I've purchased to what ampage it requires feeding with).
6. I have an instant hot water shower, currently this is switched from a 45amp pull switch in the bathroom. In 4 years this has been replaced 4 times, as the switch just breaks, 3 times in the off position resulting in not being able to shower
. I'd like to take this out, and replace it with a 45amp 'cooker switch' on the landing, is that allowed? It's being fed direct from the consumer unit, has its own RCD (if thats the right terminology?) and 10mm2 twin and earth feeding it.
