Discuss BG (British General) consumer units in the Electrical Tools and Products area at ElectriciansForums.net
TBH, I think the BG CU's are complete rubbish, however Fusebox on the other hand - I think they are much better quality than most, and a good price.
If asked for recommendations I would put Hagar top, then if the price is an issue, Fusebox.
I fully agree. I have fitted 1 supplied by a customer, has a faulty RCD and 2 faulty replacement RCDs, whether it was a bad batch or not I find it to be cheap DIY rubbish and will never fit one again.
Had quite a few issues with the BG consumer units usually trying to get the knock outs to knock out (I have had a few buckled carcase ) but never an issue getting them replaced surprisingly. Also trying to keep the breakers straight while tightening to the busbar as often look like a row of condemned houses.
When posible i have started fitting Contactum boards as they appear to be a lot more substantial also never had any issues with them. The only boards I seem to have issues with seem to be from the BG, CED, MCG type of equipment anyone got any recommendations on any decent ones with deals on them
Hi I also have had trouble with BG RCD's , was completing EICR on domestic where the BG RCD's did not trip @ 5 x, in less than 20ms which was required for TT installation, hence answer was to get PME fitted but worth noting. Never had that trouble with more well known manufacturers RCD's, tripping @ 20ms Crabtree, Wylex, hagar , etc oh yes and of course schneider
MCG, CED, axiom, BG, Chint, proteus and others I probably can't remember are all absolute crap in my books. MK boards are rubbish too but are less common now.
Hate to break it to you but MK are back now - CEF are doing the new ones with SPD (in black!) and Type A RCDs - will be interesting to see how they are if anyone wants to take the plunge....
Might want to check the regs there fella. For TT, max disconnection time 200ms, not 20. 40ms at 5X for additional protection.
Well said, for supposedly good (or was) manufacturer they are always on the huh, sorry Suffolk saying not straight
upnorth we don't mince words, we say on the pi$$.
Reply to BG (British General) consumer units in the Electrical Tools and Products area at ElectriciansForums.net
Hi all, what is the best way to configure surge protection in domestic dwellings when you have multiple consumer units? Does each consumer unit...
4K
I try to keep out of Domestic work but I have a problem at home. Currently I have a wylex fuse board with re-wire fuses. they are great because...
4K
I had a PV system installed by a local reputable manufacturer last autumn; since then, I've received conflicting advice regarding the consumer...
Hi, I recently had an EICR done at my property which unfortunately was unsatisfactory. So the electrican advised a new fuseboard from BG General...
