I f you get it working temp then you will be able to work out the start up current as well mate, then just look at your MCB curves and work it out from there. Like iamelectric said, with a D type you need to be careful with your Zs values as these are 1/4 the maximum values of a B type and 1/2 of a C type. Plus if you are testing the circuit cold i would check out the permissable values in the back of your GN3 for such a piece of equipment.
Cheers guys info is brilliant and the reason I wanted to ask before putting circuit into service.
Little Geordie boy at school was asked by the teacher to say a sentence with the word 'champion' in it.
Geordie said his 15 yr old sister was pregnant and his dad had said...........
Champion.....................that's just xXXXZZg Champion ! :)
There you go .... a perfect example of how the word "champion" can be used!! :devilish:
in scouseland we used to say eggsellent.
