This thread uses a prefix to highlight that the thread involves something central heating related. Try to use prefixes more often peeps.
Derek P
I have a grant vortex combi boiler and it has started tripping the main fuse when the programmer calls for heat.
Any ideas.
Regards
Any ideas.
Regards
Faulty Pump or Valve, do you have a maint contract for your boiler? if yes contact the provider.
Any ideas.
Regards
main fuse or RCD?
Pobably the diverter valve leaking. So as call for heating the valve moves (screw type motorised) and the seal has gone. Maybe, just a stab in the dark there.
Is that an external oil boiler?
It's worth getting someone out to look at it either way as there are a number of things it could be. Trying to diagnose long distance is guesswork at best.
Not external, internal.
Going to disconnect the pump from the PCB and call for heat from the programmer tomorrow, if it doesn't trip that would suggest it is a fault with the pump ??
Regards
Success i think, i disconnected the pump and turned the programmer on and it didn't trip.
Will post again after i get a new one fitted.
Thanks for your help.
Problem solved, when we went to remove the pump the pump cable was jammed between the front of the flame box and flame box casing, when we took the front off the cable was fried. Put a new cable in and it's all working now. Thanks for all your help Regards
Glad you sorted it, nice one.
