Discuss Bonding around house perimeter in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
M
MEGGER?
Can anyone tell me if any mechanical protection is required to a newly installed 10mm bonding cable that exits a garage wall (from consumer unit) and then approx 25m is clipped to the outside wall around a corner and enters into the kitchen to stopcock.The cable is clipped at damp proof height.The customer has concerns about this cable and has put kitchen fit on hold.:confused:
I would say yes the sun damages the PVC covering the bonding, rodents love the taste of PVC and unprotected is open to damage
Chris
I would say unless it was liable to damage then it would be o.k....the sun effect on the insulation is not really an issue as it is not a live conductor and it is greater than 6mm2....i have seen just this type of cable run for Remedial work equipotential bonding many times due to solid floors interior to the property.
spark1
Reply to Bonding around house perimeter in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
TNC-S main supply with 16mm swa supplying garage consumer unit from main consumer unit in house, then 4mm swa supplying pond equipment through...
Hi there, I’m a new member to the forum and felt like I could do with some additional insight into a fault I came across on a call-out at the...
Hi all, First post here, hope I'm compliant with the rules! I did do a quick search before asking this, but I couldn't quite come up with the...
Hi there, We're currently having a new kitchen fitted and in the process we've had some new electrical work done. The electricains are comeing...
Before I pay an electrician to come check my work, I thought it worth a post here. I don't want to pay the cost of a small car for a whole-house...
