Discuss Bonding earth to metal furring behind plasterboard. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Behind plasterboard? Hardly likely to be accessible, so not an extraneous conductive part that is likely to come into contact with a person. As above, just ensure the circuits have RCD protection
Yes there are cables running behind the plasterboard in plastic conduit . The circuit will be on a rcbo.
Imagine water gets spilled and gets behind the skirting touches the stud work which is live due to a screw that penetrated the cables.
that's why you have the RCBO.
was a case of a woman electrocuted exactly same scenario. no testing would have picked up the fault. although the report does not say, it's most likely that a RCD was not fitted to the circuit. if the metal stud had been earthed ( which is not a requirement ) it's probable that testing would have picked up a L-E short.
Worth remembering that cables concealed in walls with metallic parts and metallic frames are subject to having additional protection to them by an rcd in accordance with 415.1.1 or be mechanically protected or be installed in accordance with 522.6.204.
Earthing or bonding metallic parts in walls should not be necessary unless the metallic walls meet the definition of an extraneous conductive part
i'd never consider buying a house with studded walls, metal or wood. for me, walls should be constructed of bricks and plastered. plasterboard is for ceilings.
Welcome to the world of new builds, be it homes or commercial buildings, it’s just the way of the building trade.
If it’s not load bearing, stud it.
Wiring within metallic walls is a ball ache tho and you end up scratched to hell
it’s just the way of the building slap it up as cheap as possible trade.
corrected that for you. you can't define cardboard houses as "building", ans as for that mdf crap??????
Reply to Bonding earth to metal furring behind plasterboard. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Trying to find an armoured cable behind plasterboard and studding. It was used to supply power from the house but has been disconnected Can...
Hi All, Wondering if I can get some advice. Basically I’m having exposed joist ceilings in my house and I’m in the process of slowly changing all...
I’m not working on this… not yet anyway, but can someone tell me why there’s a fuse or a link on the earth here? The green wire is bonded to...
If you were to test a metal staircase on the side of the house on insulation resistance and it gave you a dead short. Would that need bonding...
Does AS/NZS 3000 require to earth metal wall box behind switch or socket outlet?
