Discuss Bonding earth to metal furring behind plasterboard. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
was a case of a woman electrocuted exactly same scenario. no testing would have picked up the fault. although the report does not say, it's most likely that a RCD was not fitted to the circuit. if the metal stud had been earthed ( which is not a requirement ) it's probable that testing would have picked up a L-E short.
Apart from the fact, that the testing was conducted by a Painter and Decorator, at the time of construction, there was no requirement for RCD protection.
Plasterboard walls are one thing but when you see polystyrene blocks used for 'block and beam' construction you begin to wonder!!
Reply to Bonding earth to metal furring behind plasterboard. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Trying to find an armoured cable behind plasterboard and studding. It was used to supply power from the house but has been disconnected Can...
Hi All, Wondering if I can get some advice. Basically I’m having exposed joist ceilings in my house and I’m in the process of slowly changing all...
I’m not working on this… not yet anyway, but can someone tell me why there’s a fuse or a link on the earth here? The green wire is bonded to...
If you were to test a metal staircase on the side of the house on insulation resistance and it gave you a dead short. Would that need bonding...
Does AS/NZS 3000 require to earth metal wall box behind switch or socket outlet?
