Discuss BS number for old wylex board fuses? in the Australia area at ElectriciansForums.net
3036 as long as nails not used in place of fuse wire then it's a different bs number.
yep, but you need to trim a bit off a 2" or the protruding end can play havoc with your wedding tackle
Reply to BS number for old wylex board fuses? in the Australia area at ElectriciansForums.net
Two questions: 1. I’ve had a bulb in the hall turn black with some white powdery deposits (see photo), whats caused this, guessing i should get...
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
Quick question. I want to put an isolating 2p switch on my incoming supply from the meter to the board. I want this to allow easier board changes...
I have a question which is confusing me and I cannot find a definitive answer and I hope someone can help. So I have a PC and Monitor and I have...
As per normal I was in a rush and didn't get enough information. I was working in an apartment that didn't have any power and when I went to...
