Discuss Building control / works certificate in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Jimjamyaha
Hi,
In 2005 would building control / works certificate have been required for a new / extending kitchen wiring, new ceiling lights and oven installation?
In 2007 would building control / works certificate have been required for new ceiling lights, sockets, replacement of electric shower and replacement of a ventilation fan in a bathroom/utility room?
Asking as work done in a property to purchase. Vendor and builders being quite certain that certificate or building control not required.
We are suspicious as after an EICR basic faults found (no grommets in backboxes, lights not fire rated for a ceiling... Could go on).
Many thanks for your professional replies.
As far as I recall, Part P was introduced in 2005.
Any work started, or work where planning permission had been given before the introduction of Part P, would not have been required to comply.
That being said, the lack of grommets is more a non-compliance with electrical Regulations than a non-compliance with Part P.
Would need more information regarding the lack of fire rating for the lights.
Like for like replacement in the bathroom providing no alterations took place, no. Utility room could be a grey area if associated with the kitchen.
Thanks everyone for your replies.
So, to sum up so far. Work in kitchen was a notifiable location according to Part P which was valid from 1 Jan 2005.
Work took place after this in mid/late 2005.
New lights and sockets were introduced (possibly on a new circuit as EICR found 2 circuits present in kitchen). The light are recessed spots in the ceiling and def not fire-rated and are in a plasterboard ceiling. Above are 3 further stories of house.
For the utility room (really a downstairs bathroom) (separated by a door from the kitchen) in 2007 this involved a refurb of replacing a ventilation fan, an electric shower but in a new location/larger size of shower area (although no confirmation that the unit power was actually like-for-like, could have easily been uprated), new ceiling lights added, new sockets added.
EICR findings:
Reply to Building control / works certificate in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all, I am a home owner and our builder has completed a garage conversion with the electrician installing a new 4 way distribution board. The...
As per Part P of Building Regs, once electrical work is performed by a registered competent person, the installation certificate needs to be given...
Hi, New to the forum. I have two very specific questions, for the setup below. Setup details: Currently I have a setup with an outlet used for...
A relative recently had an electrical certification done on a rented property. The property was build in 2005 and had previously passed 3...
Hi Everyone, This is my last question/post for tonight, promise. Please can I ask for a little advice on certificates as I am now questioning...
