As I say, the measured 22v was between the ends of 2 of the disconnected 2 way switch wires and earth (ceiling rose earth, which was giving 230v to phase, 0v to neutral as one would expect) - in other words measured at the ends of (in theory) a piece of wire!!
altho as I also alluded to, there must be some sort of connection between the 2 ends as the landing end is rubber sheath and the hall end pvc, so altho not impossible, there should be no need for earths or neutrals around the sw wires at all?
Theres no earth wires at all in the switch boxes.
I did strongly recommend a rewire due to the age of the lighting wiring which the customer agreed was probably a good idea.. I left it with her..
