Discuss Cable Current Capacity - Solar Inverter vs Normal Loads in the DIY Electrical Advice area at ElectriciansForums.net
aesmith
Hi,first off this does not relate to work I intend to DIY. I'm trying to sanity check information I've been asked to provide to the installers.
I want the solar invertert to connect in the garage, where there's a DB fed from the house via SWA.
This is what's asked ..
As the proposed PV inverter is 5kW (21A) we would need to know what loads are regularly used in the garage to know if the 25mm2 cable has enough “room” left in it to carry an additional 21A.
I can provide information on the loads as requested, but then i started to think isn't this the wrong way round? Won't solar generation be subtracting from the load rather than adding to it? Or does it not work that way?
Reply to Cable Current Capacity - Solar Inverter vs Normal Loads in the DIY Electrical Advice area at ElectriciansForums.net
I have a bathroom fan with a moisture detector that turns it on and off. It also has a control circuit to turn it on/off when moisture is not...
I don't "do" solar, but I've been asked to comment on an aspect of a new domestic solar installation by others. There is no overload or fault...
Good Morning All! Always appreciate reading the great ideas and conversations in the forums, and now actually have a chance to ask a question...
Hi all. We have had 7x 400w solar panels for a number of years now on our roof which is se/nw facing end terrace. 4 on se side 3 on nw side...
So, I already have solar (an older FITS installation) and it's been particularly successful so I want to extend this. I'd like to do two things at...
