T
The Ghost
So call out to kitchen desperate to get hob working. Described big bang, MCB triggered to off. Turned back on and nothing. As you can't turn on the separate coils unless the unit is powered up how can you test it? Anyway did IR between L-N and got 0.23 Mohm so assumed something had gone into meltdown, replaced with new induction hob, Beko 7.2kw.
Just got me to thinking with electronic switching and no way of switching on the individual rings I wonder how you can realistically test it without taking the thing apart (if it is even worth the trouble) and testing at the physical induction coils. Anyone know of this sort of thing? I must say the cable entry to the hob was flattened/distorted and looked a likely point of shorting as it was compressed on the crosspiece of the carcase so I cut a hole at the point of the entry to allow obviation of compression. Also underneath the hob was an oven 3kw all on the same circuit with no ventilation which I don't imagine would help. This was on a 32a MCB and 6mm² supply cable. I have done the maths before someone tells me "I would never wire 10kw on to 6mm²" or something equally inane. I could only advise the customer the circuit was not adequate for the load and they should consider another point for the oven.
