Discuss Can I put these two cables together? in the UK Electrical Forum area at ElectriciansForums.net
Hi, got a cctv and a flood light power cable outside which I want to put in a conduit pipe. Can I put both cables inside the same conduit or they have to be separated to avoid interferance with the cctv camera? Many thanks
Are we talking RG59 here? Or are we talking about a mains cable for a camera that'll be plugged into a socket? If it's the first, then yes segregation is required. The latter, nah.
Hi one of cables is an ordinary power cable going to a flood light next to the cctv camera and the cctv cable looks to me like a coaxial for the picture, sorry not sure what names they have. I simply want to avoid using 2 pipes/conduits if i can as long as it doesnt cause any problems to the cctv picture from electrical interference
as hightower stated. it's not just the possibility of interference. the coax will not be rated for mains voltage, so it's a no no as regards compliance with regs., but for a short run through a wall, as long as there's a bit of space in the conduit, i can't see it being a disaster.
Hi - Often the coax is outdoor rated so it could be run tacked next to the existing conduit. Just a thought.
Interference can be tricky and depends many factors, the quality of cable, length of run, installation practice, camera susceptibility etc. I would do a little test with the camera and cables at ground level perhaps.
Agree with Wilko - the quality of cable is the biggest factor as regards interference. Cheap crap cox doesn't even have 100% screening coverage, whereas good quality (decent brand CT100, etc.) stuff has a full screen and will usually keep out most interference. Daz
Reply to Can I put these two cables together? in the UK Electrical Forum area at ElectriciansForums.net
Hi! I have a led strip (12V) with an external cable (2*1mm) glued on the wall and it's not fancy at all.. Inside the wall I have 3*1,5mm cable...
I would like to run power to a shed that is 40m from my other shed which is powered by a 10mm cable from the house. I have access to a 100m roll...
Hi, I'm running a 70ft underground UF cable in 3/4 inch PVC conduit to 2 sheds. The sheds are 3ft from each other. I'm just a DIYer enthusiast so...
I live in a warehouse condo, converted about 20 years ago. The building dates to about 1870 but with the conversion, all of the electrical was...
Hello, I have 50 ft of corrugated pipe buried between my house and a pool shed. I placed it where I knew future landscaping would make it very...
