Discuss Can you feed 2 radials from one fused spur in the UK Electrical Forum area at ElectriciansForums.net
You have diagnosed the problem
You have enquired as to compliance
You have suggested a sensible solution,it will leave the existing sockets as safe as they were when they were on a needless ring final
It may not be an ideal way to wire a radial(if you were starting from new) but 2 branches should be ok
It even has advantage in that the final Zs will be lower than if it was conventional socket to socket jobbie
Thanks Des 56
Reply to Can you feed 2 radials from one fused spur in the UK Electrical Forum area at ElectriciansForums.net
Hello all. I have just bought my first house but it needs a bit of work. I am re-wiring it and I've found the conservatory ring has been spurred...
i have just started my course as a trainee electrician...some advice on the following will be appreciated: I have a spare 16 and 32A MCB (RCD...
Grateful if someone could offer some advise, I'm struggling to find a definitive answer to this. I have a double socket, it was on the ring main...
A recent EICR turned up a fault: an RCD fused spur was feeding a socket and a shower pump, and neither socket or pump had continuity on the CPC...
Hi! I've got a couple of 32A Wago clips. Creating a spur socket from a ring circuit with these is quite easy, but I wanted to know if it's...
