V
vwes59
I've been trying to locate anything in the regs that say this can't be done, but can't see anything.
Basically I have a 3kw oven on a 4mm T&E cable going to a 32A MCB (Cable is clipped direct in loft to consumer board, and not covered by anything en-route - property is a bungalow). The isolator already has 1 socket, however a requirement has occurred to have a second socket for a built in Microwave (800W). The first socket is in use on the kitchen worktop, this 2nd socket will be hidden away behind the cooker and microwave.
The circuit can handle the extra load, but is it allowed under the regs to have more than one socket on a cooker circuit. Yes I could just spur off the ring, but the nearest socket is on the other side of the worktop and I'd have to chase out a substantial amount of wall to get it done, whereas this way I would only need to chase about half a metre.
