Oct 27, 2020
117
29
103
UK
Hi,
It's got to a point that our poor car just isn't cutting the mustard anymore. It was never designed to be used as an electricians car. Up to now I've managed, but I've got much bigger jobs coming up needing to work at height, transporting conduit and so on, so it has to go.
With family restrictions I can't go with a van or pickup, as my as my daughter would love one, but it has to be a car, specifically either an estate, SUV or MPV.
So I wondered if anyone out there uses their family car for work, and if so, have you been able to fit pipe carriers and ladders to its roof. Love to hear people's recommendations.
We used to own a Qashqai+2 and that was like a Tardis with what we could get inside, but it's roof just doesn't seem to suit long straight carriers, so that's probably out. I'm tempted by a Freelander 2, much flatter roof, downside it's a diesel, and I've been bitten once before when a diesel car goes wrong (£3k repair bill for a DPF which effectively wrote it off), so not keen to repeat that.
VW....long roof, loads of room inside,...... and you can also go on holidayin it.
Reactions: cloverman
Like Strima has said ! I have a crewcab van, one of my best decisions I have to say on the transport front ! I had several vans over the years and although I also had use of a car it become a bit of a pain having to come back to swop over vehicles to pick grandkids up etc,.
Looks like we've found a car that'll do the job, a 2006 Honda CR-V that has a side opening boot. After 2006 they switched to the usual hatch back design.
If the Honda doesn't work out, and you're happy with a car of that age, the Vectra C estate is basically a shed on wheels. Huge load space, big square opening and a long flat roof - I replaced mine with an Insignia and still mourn the loss of practicality.
Seat Alhambra / VW Sharan
I have a 2004 Seat Alhambra currently has 195,000 on it and is a nice motor take row 2 & 3 seats out and you have a massive load space, seats can be removed or replaced in minutes and used in different configurations
Jeep Cherokee 4L straight 6 petrol. sod the climate.
  • Funny
Reactions: DPG
I've always used a car for work, but with a towbar, and a trailer behind when necessary. For the first twenty years it was a Mini saloon (original type), with half a matching Mini van towed behind it. The car had a roof bar, and so did the van, and could easily carry the longest ladders and the 6m lengths of pipe/conduit that were standard at the time, with no overhang. Load secured firmly at the front, and with a little bit of slack at the back.
Where abouts in the country are you? I have a second hand trunking/conduit 3m tube for sale if you're interested? I bought a longer van and don't need it any more.
Just bare in mind if you passed your test after 1997 you might need to do an extra driving test to pull some trailers.
Don't think that's true any more. Now it only applies to trailers above a certain weight.
Just looked it up. No extra licence required up to 3500 kg total weight of car and trailer.
my van is 3500kg if fully loaded. it has a warning sticker saying a tacho may be required with a trailer.
  • Agree
Reactions: UNG
It's the gross laden weight they go on. My 2.9T pick-up + a 750kg trailer is over 3.5T so needs B+E and a tacho (unless covered by an exemption such as transporting tools & materials I am personally using up to 60 miles from base).
  • Agree
Reactions: UNG
Remember many years ago a plumber turned up on a job in an old car and the site agent implied he may as well brought his horse and wore a stetson.
Made me wonder what image is portrayed when a tradesman turns up in the family car.
Mind you, seen loads since so I guess it doesn't really matter if you turn up on a bike as long as the job is done well?
Conversely, one of the worst cowboys I know of in my area owned an immaculate sign written van, never over two years old. Book.......cover?
  • Agree
Reactions: pc1966 and DefyG
..........unless covered by an exemption such as transporting tools & materials I am personally using up to 60 miles from base).
My matching car and trailer were classic Minis, so you'd struggle to get anywhere near 3.5 tonne, unless loaded with concrete blocks or similar.
The car I used for the majority of my career had an unladen weight of 1300kg, so again, I would have to be carrying building materials, rather than electrical or plumbing stuff to get anywhere near the limit. 3500kg all up would have also exceeded the towing limit of the car as well, not that I worried too much about tht detail.
These cars have always been stripped out to just the driver's seat, and a large flat load area fitted where the rear seats should be.
The car I've used in recent years (BMW 5 series touring) is not stripped out, but has a massive load space anyway. It has an unladen weight of 1700kg and a towing limit of 2200kg, so easy to go over 3500kg with that, but my licence is pre '97, so 8250kg limit anyway.
And over 3500kg you would need a tachograph fitted when used for business
This covers 99.9% of my activities.
Mine too. Used to be a bit awkward occasionally when I towed with a car before they doubled it from 50km to 100km, but now I can get my kit for most jobs in the truck I don't care so much.
What I do care about is the derv bill, that's not so clever.
That's the other advantage of using a car instead of a van. I don't have to get involved with that filthy diesel muck.
All my car's run on the only truly green fuel. LPG.
The Dacia Sandero might be a cheap petrol option
Dacia have just introduced some LPG powered models into their range. No idea if it includes the Sandeep.
And where does LPG come from that makes it green, ISTR that LPG was introduced and used as a cheaper alternative to petrol in large engined vehicles
Hydrogen is the only really green fuel the problem is in some methods of it's production that are not so green
LPG is produced as one of the products from refining crude oil. The amount inevitably produced far exceeds its demand, so the excess is flared off.
The exhaust of my cars consists mostly of water and CO2 (I can work in my unventilated workshop with the engine running with no danger of harm).
If the CO2 wasn't coming from my exhaust, as a result of me consuming some of this excess product, then the same amount of CO2 would be coming from a flare stack somewhere.
My car qualifies in the lowest pollution category of the French Crit'aire scheme (1), apart from that awarded to pure electric vehicles (0).
So it produces a gas whose emission levels we are trying to reduce in order to be green, just shows how stupid the French are when it comes to pollution
With regard to working in an unventilated workshop with the engine running it will deplete the ambient oxygen levels which would result in an incomplete burn and LPG does produce carbon monoxide which can kill
Reactions: pc1966
Once the oil is out of the ground, to keep all your petrol and derv vehicles going, the CO2 from the LPG fraction will be going into the atmosphere regardless, whether it is from the top of a flare stack, or from my tail pipe.
My workshop is about 1000 cubic metres, and is far from hermitically sealed. Plenty of oxygen for me ans a whole tank of LPG.
It's not just the French, BTW. I could apply for a similar exemption certificate in many European countries. AFAIK, it's only the UK that won't.
Gone with a 2006 Honda CR-V, 95k miles, 12 Months MOT, no advisories, fully serviced at a knats over £3k. One of the last to have a side opening rear door. I'll retrofit roof rails later.
Easily mitigated with LPG at 54p a litre and the extended service intervals.
What is the service interval? Everything I've seen says 12,000 miles but that seems low
I wouldn't go much above 12,000 miles for any oil, whatever the fuel. At that kind of mileage the oil will be degrading because of the mechanical 'chopping' effect on the long chain oil molecules. There's a difference between what's best for an engine, and what's best for sales when you're selling to fleet managers, who will be typically selling the vehicles on after two years.
What you won't have is anything like the amount of contaminants in the oil, since you don't have LPG condensing out of the mixture in a cold engine and contaminating the oil, unlike petrol, or anything like the amount of acids formed in the combustion process that end up in the oil.
It can be seen when you change the oil. That from an LPG engine often retains some of the golden colour of what you put in.
I never considered the oil going bad. I drive around 65,000 miles a year in work and have overnight servicing every 25,000. I couldn't imagine taking it to the garage 5+ times a year but for home use the LPG sounds brilliant.
but the conversion to lpg is ££££££s. i jsu t used to have Esso tanker following me.
Cost of converting my current 5 series was £1800, but the trick is to let the previous owner pay it. Converted vehicles don't carry much of a price premium in the UK.
Alternatively, buy a suitable damaged or otherwise expired ready converted vehicle, strip the kit out, and fit in to a vehicle of your choice.
I've had a couple of LPG vehicles over the years. One a factory installation, which came cheap due to a gas leak and the other converted by its previous owner.
Liked them a lot and would buy another if they were more readily available. I've no interest in having one converted, so just bought diesels since.
UK
Car Suggestions - Pipe Carriers, Ladders
Electrical Tools and Products
vwes59,
nicebutdim,
