Discuss ccu rcds in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
C
carl sparks
hi guys just thinking about something when u change a cu as a upgrade r u putting everthing on rcds ie bathroom light on the upstairs ciruit and the other thing because of the cables not being 50mm in the wall do these have to be protected aswell :eek::eek::eek:
Carl,
Look at regulation 522.6.6 and then read 522.6.7 this will give you the full answer to your question.
Hope this helps
BillR3
Reply to ccu rcds in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I'm obviously still new and learning about what I can and cannot do, but essentially I want to install an EVSE at my own house for an electric...
Hello! I've been racking my brain this evening about some RCD selections. I've been doing some work for a solar installer, and they've asked me...
Well....wiring in a 1750s thatched cottage attic, not wiring made from thatch 🤪 One we have been letting for over 20 years (as well as enjoying...
4K
I'm doing a college design project and need to choose a suitable range of circuit protective devices for the whole contact. I've chosen and...
