Discuss central heating wiring in the Australia area at ElectriciansForums.net
S
simonatlondon
Hi guys,
Ant help would be great. I am about to do a complete rewire, I need some information on wiring up a system that will incorporate a boiler, time clock, stat and perhaps an immersion.
I would like some pointers please of where I can look up the required wiring.
Thanks.
Have you tried looking on the boiler manufacturers web site and the web site for the timer etc.? not always easy to get the info, sometimes the installer of the boiler may be able to help.
monty there will be a pump, valve etc etc. Its a basic domestic system. A few rooms will have underfloor heating which will be operated by their own stats and manifold. I really do need a diagram that I can look up.
cheers
Central heating wiring can be quite complicated for a novice, and I have seen some qualified sparks struggle if they are not familier. If you are not careful you can end up with backfeeds, valves doing funny things etc etc.
Best get a decent electrician in who knows the crack.
Immersion heater is streight forward. That is normally just a 16a radial circuit in 2.5 with a 20a double pole switch to turn it on and off,(in kitchen or wherever) and another 20a double pole switch as an isolator next to the heater, and 2.5 TQ flex to heater it self.
If you are in Yorkshire I will come and do it for you !
Thanks spudmeister, im in london. i've been a sparky for a little while now but no experience on this side of the installs. What do you guys think of the short courses available that teach central heating wiring? I have been looking some of these up and they seem to fit the gap in my knowledge.
So sorry monty. Thanks very much.
That diagram you posted is fantastic. Its exactly what im looking for. Are they alway manufacterer specific?
Thats alright lol
Yes generally manufacturer specific but everything you need to know is on there just use your own literature to adjust
hope it all goes well:)
yeah ch systems can be i bit of a brain tease, when i used to work for british gas they had there own wiring centres and a bag of links wires, you couldnt go wrong as everything was labelled up, however you didnt really learn for future jobs where there are no drawings. once you becomre familiar, you just think of it as been a series of switch wires, often helps to know what the valve does as well, like when the brown is energised that brings the orange on which brings the boiler on and on and on!
good luck
Sorry Simon, diddnt read thread properly, thought you were a householder not a spark.
I used to work for an industrial heating company that did fairly big jobs and enjoyed all aspects of heating installs.
Will help where I can , it depends what system you are using, but google Y plan or S plan and that should bring up a few diagrams.
any questions , just ask.
Reply to central heating wiring in the Australia area at ElectriciansForums.net
Hey everyone, hope you all had a good xmas. Got called around to change over an old style pin type thermostat to a hive one for a family member...
I have not had to do the wiring for a wet underfloor heating system before. I think I started a thread fairly recently and had some very good...
I have a fully pumped Y plan heating system using a Potterton EP2 programmer. Drayton MA1 Diverter valve. I have just replaced the Actuator head...
Up until now I have steered clear of heating systems. I now have quite a bit of work with a builder and will be expected to deal with the...
