Guest viewing limit reached
Got to do a install cert and EICR for same job.
anyone know if you can copy details from one cert to another instead of typing everything up twice ??
using NIC online certificate
which comes first. EIC or EICR? if youare doing a EIC for intalled works, followed by an EICR, then all test results can be copied as long as nothing is altered between the two.
Wiltshire
Trainee Electrician
Certificate question
Nick...,
Nick...,
