Discuss Cheap Voltage and continuity tester? in the Electrical Tools and Products area at ElectriciansForums.net
I have one of these and it does the job well:
If you don't need continuity testing then this is the daddy of them all:Martindale VT12 Voltage and Continuity Tester
Martindale VT12 Voltage & Continuity Tester - MARVT12 The Brand New Martindale VT12 is an excellent value Voltage and Continuity tester for universal applications. The VT12 is constructed in accordance with the latest safety standards and guarantees safe and reliable measurements and...www.test-meter.co.uk
But equally you get cheap voltage-only testers such as this from the DIY houses:Drummond MTL20 Test Lamp
John Drummond Test Lamp MTL20 The John Drummond MTL20 Test Lamp gives safe indication of voltage between 50V and 500V AC/DC. The MTL20 test lamp housing and probe both have a finger shield and insulated probe tip with only 4mm of exposed metal. A two layer double insulated cable with white...www.test-meter.co.uk
All testers should be "proved" before and after use by testing on a known voltage source to check they are really working. Some models claim to be self-proving, and to some extend the likes of the Martindale tester (above) will let you know something is working just by checking it bleeps on continuity, but as a professional then something like this is worth considering:TIS Voltage Tester
• Voltage range 12V to 690V • Automatic polarity indication • One hand operation for testing sockets• Compact pocket size design• Probe tip protection• No batteries required• Extra bright LEDs• Does not trip RCDswww.toolstation.com
Otherwise you really must check the tester on a known live supply first, and obviously that is a dangerous step to take compared to a limited-energy battery unit designed for testing.4299 Proving Unit
Intelligent voltage ramp testing for voltage indicators and multimeterswww.cef.co.uk
OK.Oh nice brilliant thank you so much for yhat I'll have a quick look at them now.
It is not the same thing. The usual "voltage tester" takes a mA or two to drive the LEDs and that allows it to check there is a real power supply there, and not a few uA of current from capacitive coupling (AKA "phantom voltage").My dad just gave me this as he just found it jn his cupbard he bought years ago.. Seems like this is different as voltage check goes only up to 600v.
Is that correct?
Looking on the interweb there are ad's everywhere for it! And youtube vids!My dad just gave me this as he just found it jn his cupbard he bought years ago.. Seems like this is different as voltage check goes only up to 600v.
It does seem to be a 'proper' cat III multimeter, but with an input impedance of 10Meg, so it will suffer from the 'ghost voltage' syndrome mentioned above.
While the voltage ranges go up to 600v, the DC and AC current ranges are limited to mV and mA, so it seems more suited to electronics work.
So all in all good for experimenting on battery and low voltage things, but not for mains work, especially dead testing.
I think you've had some excellent answers already. My 2 cents is that a 2 pole tester is a great (if not essential) investment and the TIS unit above does the job well. For proving dead, and basic continuity or no continuity it's fine.
Being able to measure very small resistances accurately and perform insulation resistance test is the next step, and assuming you aren't ready to shell out for a multifunction tester, then keep a look out for the Megger BM series, that can do 250 and 500v insulation tests and continuity tests to an accuracy of 0.01 ohms. They come up on ebay quite a lot and are fantastic little testers.
Also keep an eye out for Megger 15xx series multi-function testers that are still in calibration, occasionally these come up for silly money as they are getting a bit old now, but they are extremely well made (better than the 17xx series IMHO) and do the job.
Hope that helps.
You need either a MFT or a simple 'Megger MIT230' style of IR tester that gives you low resistance measurements at enough current to show poor joints, etc. If on a budget then a 2nd hand one might be found for £100 or so.To do ab R1+R2 testing, continuity, resistance testing would I need a multifunction tester or can I do it on a simple 2 pole voltage tester?
For professional work you would be expected to have it calibrated once per year, cost varies but CEF do "calibration days" where you hand it in and it is about £30 per item.Also how often do they need collaborating ? Is it expensive ? And is is it mandatory?
Or new on a budget, something like this:
Test Meter PRO TMP600 Electrical Insulation Tester
#html-body [data-pb-style=RKRH7Q9]{justify-content:flex-start;display:flex;flex-direction:column;background-position:left top;background-size:cover;background-repeat:no-repeat;background-attachment:scroll;border-style:none;border-width:1px;border-radius:0;margin:0 0 10px;padding:10px}#html-body...www.test-meter.co.uk
In between, and if on budget/hobby, then the CalCard gives you a very good indication for IR and continuity testing:
However, that won't check other aspects of a MFT, like RCD testing, Zs measurement, etc. But in most cases modern meters are either working or very broken, so the calcard would show something up. Probably in over half of the cases of dodgy measurements the test leads are to blame, so a spare set is worth getting if you suspect the meter is unreliable before damning it.
Reply to Cheap Voltage and continuity tester? in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for. It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online. Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
We also have a Tiling Tools advice from the worlds largest Tiling community. And then the Plumbers Forums with Plumbers Tools Advice.
